WIMA MKP-2 Polypropylene Capacitor 5mm 630V 22nF
These WIMA MKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 10%, a very low dissipation factor and a low level of dielectric absorption. Their filtering capacity allows them to be used in a wide range of applications.
Reference : 17745
0,40 €tax incl.
0,33 € tax excl.
Shipping date: 25-03-2025.
WIMA MKP-2
WIMA MKP-2 Condensateur polypropylène 5mm 630V 22nf
These WIMA MKP-2 capacitors are made of a polypropylene dielectric. They benefit from a tolerance of 10%, a very low dissipation factor and a low level of dielectric absorption. Their filtering capacity allows them to be used in a wide range of applications. Moreover, they have an extended service life, even at high temperatures.
Product typeCapacitor
Capacity22nF
Voltage630V
250VAC
Tolerance10%
DielectricPolypropylene foil (PP)
ElectrodesMetal foil
Temperature range-55°C to +100°C
Insulation resistance (@+20°C)≥ 3x104MΩ @ +20°C
Dielectric absorption0.05%
Operational life> 300000h
Dissipation factor (@ +20°C)≤ 0.5x10-3 @ 1kHz
≤ 0.8x10-3 @ 10kHz
≤ 3.0x10-3 @ 100kHz
RoHS
Dimensions7.2*5.5*11.5mm
Contacts spacing5mm
Tolerance (%)10
Capacitor capacitance (µF)0.022
Rated voltage (V)630.0
Capacitor typeFilm capacitor
Capacitor formatRadial
These WIMA MKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 10%, a very low dissipation factor and a low...
