Effectivement c'est écrit en petit dans la description détaillée mais ce récepteur bluetooth est livré sans alimentation et ce n'est pas une alimentation USB C donc il faut l'alimentation spécifique 12V. Dommage
Bluetooth 5.0 aptX-HD CSR8675 DAC PCM5102 24bit 48khz
This Bluetooth receiver includes a CSR8675 chip with the Bluetooth 5.0 standard and supports the aptX and aptX-HD protocols. It therefore has a higher transmission rate and stability than standard Bluetooth. In addition, this chip, combined with a PCM5102 DAC, supports PCM sampling rates up to 24bit 48kHz. Enough to enjoy your favorite songs in high resolution! A PDO just before the stereo RCA output amplifies the signal. Mounted on a DIP8 bracket, it can easily be modified to adapt the sound to your listening and your audio system.
Specifications | ||
Product type | Bluetooth receiver | |
Bluetooth chip | CSR8675 | |
Bluetooth version | 5.0 | |
Supported Bluetooth protocols | aptX aptX-HD | |
DAC Chip | PCM5102 | |
Supported sampling rate | 24bit 48kHz | |
Input | Bluetooth | |
Line output | 1x Stereo RCA / 1x Stereo Jack |
General | ||
Dimensions | 72.5 x 80 x 29.6mm | |
Voltage supply | 12V DC via Jack DC 5.5/2.1mm (power supply sold separately) | |
Housing material | Brushed Aluminium | |
Color | Black | |
Package | 1x Bluetooth receiver 1x Bluetooth antenna |
Input | Bluetooth |
Output | RCA |
DAC / ADC Chip | PCM5102 |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | aptX LL |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | aptX HD |
Supported Bluetooth codecs | SBC |
Average votes 5.0 / 5 10 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Erwan S.
Jérémy G.
patrick a.
Bastiaan v.
