Excellente conception pour ce petit boîtier, son dynamique et précis. Destiné à redonner vie à un vieil ampli de trente ans d'âge et enceintes de qualité, je suis ravi.
Livraison rapide et soignée.
This product has been replaced by the new version, the FIIO BTA30 PRO Bluetooth receiver with DAC ES9038Q2M.
Bluetooth 5.0 Receiver / Transmitter CSR8675 DAC AK4490 aptX-HD LDAC 24bit 192kHz
Versatile and powerful, the FiiO BTA30 is a Bluetooth receiver and transmitter, but also a DAC. Featuring a complete set of connectivity, a control application and very good sound qualities, the BTA30 is the ideal companion to enjoy your music with ease.
The BTA30 offers 3 distinct operating modes: Bluetooth reception (BT Rx), Bluetooth transmission (BT Tx) and DAC. The selection is made simply by a button on the front of the device. The embedded Bluetooth chip supports high resolution codecs such as aptX-HD and LDAC.
Although compact, the BTA30 is equipped with a complete set of connectors. It is equipped with Bluetooth 5.0, Toslink Optics, Coaxial and USB-C. At the output, the device offers Bluetooth, Optical, Coaxial and RCA line output.
The coaxial input and output are shared on a single connector.
The USB-C connector allows both data transmission and power supply to the unit.
Bluetooth reception and transmission of the BTA30 is enabled by a Qualcomm CSR8675 Bluetooth chip, supporting transmission up to 24bit 96kHz (depending on the codec used).
The BTA30 also features an independent CR5302SN DSP, which allows the BTA30 to tune to the different formats supported by the camera. In addition, it allows 192kHz upsampling of all digital audio streams for improved accuracy and listening experience.
The digital/analog conversion is carried out by an AKM AK4490 chip with excellent performance. Its implementation allows you to enjoy a great sound richness thanks to a better SNR and a better dynamic range than the DAC integrated in the Bluetooth chip. The DAC is combined with film capacitors for clearer and more transparent highs.
The BTA30 incorporates a high level volume control. This allows a precise adjustment of the sound level thanks to the ADC curve reconstruction. It acts on both digital and analog output volume and can be remotely controlled via the mobile application.
When using the unit in USB DAC mode, the volume control cannot be used.
Your smartphone, when connected to the BTA30, can control the BTA30 via the FiiO Music or FiiO Control application. The application allows you to act on the balance, filters, Bluetooth format priority, to disable LED indicators, to adjust the volume level and to activate a fixed output level.
Download FiiO Control app for Android
Download FiiO Control app for iOS
Download FiiO Music app for Android
Download FiiO Music app for iOS
The BTA30 has the dual certification of Hi-Res Audio and Hi-Res Audio Wireless, awarded by the Japan Audio Society. These certifications guarantee high quality sound reproduction.
Product type | Bluetooth Receiver |
Inputs | Bluetooth 5.0 1x USB-C 1x Optical Toslink 1x Coaxial (shared with the output) |
Outputs | 1x Optical Toslink 1x Coaxial (shared with the input) 1x RCA stéréo |
Bluetooth Chip | CSR8675 |
DSP Chip | CR5302 |
DAC Chip | AK4490 |
AOP | OPA1662 |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX-HD, aptX LL, LDAC |
Supported sampling rates | Optique : PCM jusqu'à 24bit 96kHz Coaxial : PCM jusqu'à 24bit 192kHz, DSD64 (DoP) USB : PCM jusqu'à 16bit 48kHz |
Transmission range | Approx. 30m (without obstacles, SBC codec) |
LED Indicators | SBC : Blue AAC : Teal aptX HD : Yellow aptX : Purple aptX LL : Green LDAC : White |
Analog output level | Max 3Vrms |
THD+N (RCA) | 0.002% (SPDIF input 24bit 48kHz, 1kHz -3dB) |
SNR (RCA) | 115dB |
Housing material | Aluminum |
Color | Black |
Dimensions | 120 x 55 x 23.5mm |
Weight | 115g |
Package | 1x FiiO BTA30 1x Bluetooth Antenna 1x USB Cable 1x RCA Cable |
Input | SPDIF |
Input | Bluetooth |
Input | Optical |
Output | Coaxial SPDIF |
Output | RCA |
Output | Bluetooth |
Output | Optical Toslink |
DAC / ADC Chip | AK4490 |
Color | Black |
Average votes 5.0 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Pascal P.
TRISTAN A.
Frederic L.
Thomas B.
Thierry B.
