IFI AUDIO ZEN BLUE Bluetooth 5.0 Receiver QCC5100 aptX-HD LDAC Balanced
iFi Audio's Zen Blue is the first Bluetooth receiver on the market to support all the latest Hi-Res codecs, providing the best possible audio quality for remote transmission directly from your smartphone / tablet to your high-fidelity audio system.
Reference : 14118
149,00 €tax incl.
124,17 € tax excl.
This product has been replaced by the new version, the IFI AUDIO ZEN BLUE V2 Bluetooth 5.0 receiver QCC5100.
iFi Audio Zen Blue
iFi Audio Zen Blue Récepteur Bluetooth 5.0 QCC5100 aptX-HD LDAC Symétrique
Compact, versatile, stylish and extremely powerful, Zen Blue is a concentrate of technologies ideal for music lovers who want to enjoy the remote distribution of their audio files.
Bluetooth 5.0, aptX-HD, LDAC, HWA
The way the Bluetooth receiving circuit is integrated, its signal processing quality and all the surrounding circuits have a huge impact on audio performance. iFi Audio has therefore worked to ensure that Zen Blue can offer the best possible sound quality.
As a result, all the latest Bluetooth audio protocols and codes are supported, including Qualcomm's aptX-HD, Sony's LDAC and Huawei's HWA. Other supported codecs are aptX, aptX Low Latency, AAC and SBC. This complete coverage of Bluetooth codecs by Zen Blue allows it to ensure full compatibility with source devices, while allowing you to enjoy the highest audio resolution currently supported by Bluetooth.
In addition, Zen Blue is able to record the pairing of 7 source devices, allowing you to switch quickly from one device to another, while taking advantage of the wide reception range offered by Bluetooth in version 5.0.
The DAC stage of Zen Blue supports much higher sampling rates than Bluetooth currently allows. Thus it will never be an obstacle in the playback of your Hi-Res audio files, and will also provide a high level conversion for a rich, dynamic and transparent playback.
On the interface side, nothing could be easier. The LED in the center of the front panel of the Zen Blue changes color to allow you to easily identify the Bluetooth codec currently in use. The LED on the right allows you to indicate the sampling rate of the read file. Finally, the QCC5100 Bluetooth chip can be updated remotely, so that future Bluetooth codecs can be added to Zen Blue.
Qualcomm QCC5100 & DAC ESS
The entire Zen Blue architecture benefits from intelligent design, starting with the integration of the excellent Qualcomm QCC5100 Bluetooth receiver chip, enabling fast and efficient audio stream processing.
Although this Bluetooth chip also integrates a digital-to-analog converter, iFi Audio has chosen to integrate an independent and more powerful ESS Sabre DAC chip. The ESS Sabre chips use proprietary HyperStream and Time Domain Jitter Eliminator technologies, ensuring low distortion, very low jitter level and improved dynamics.
Complete connectivity & balanced output
Particularly versatile and able to be integrated into the vast majority of HiFi audio systems, Zen Blue offers a very complete range of digital and analog connectors. The rear panel thus integrates a stereo RCA output, a S/PDIF Coaxial output, and a Toslink Optical output. Rarer for a product in this price range, Zen Blue also has a balanced output on a 4.4mm jack connector, which reduces interference and crosstalk. A switch is used to select the path taken by the digital signal: via the DAC and then to the analog outputs or directly to the digital outputs.
Product typeBluetooth receiver
Bluetooth chipQualcomm QCC5100
DAC chipESS Sabre
InputBluetooth 5.0
1x Coaxial S/PDIF
1x Optical Toslink
1x Balanced Jack 4.4mm
Supported Bluetooth codecsaptX, aptX LL, aptX-HD
LDAC
HWA
AAC
SBC
Frequency response20Hz - 20kHz < +0/-0.5dB (44.1kHz)
1Hz - 44kHz < +0/-3dB (>= 88.2kHz)
Output voltage (@ 0dBFS)2.005V (+/-0.05V)
Dynamic range109dB (A)
SNR109dB (A) @ 0dBFS
THD+N @ 0dBFS< 0.0015% (charge 10k)
Output impedance< 50Ω
Consumption< 2.5W
Dimensions158 x 100 x 35mm
Housing materialAluminium
Weight476g
OutputOptical Toslink
OutputCoaxial SPDIF
OutputJack 4.4mm
DAC / ADC ChipES9018K2M
ColorSilver
7 reviews
Christian
Très bon produit
Surpris par la qualité de la restitution sonore dans l’espace
This review has been posted for IFI AUDIO ZEN BLUE Bluetooth 5.0 Receiver QCC5100 aptX-HD LDAC Balanced
vraiment top rien a dire
Unité BT au top
D'abord la polyvalence de cet appareil. Il propose des sorties numériques et analogiques. Beaucoup de codecs BT, dont les HD avec le LDAC et le Huawei notamment.
J'ai essayé sur sorties analogiques RCA, le décodage passe par le dac interne à base de Sabre du Zen Blue.
En numérique je suis passé par la sortie coaxiale RCA du Zen Blue, avec câble Canare/Audiophonics vers un dac Soekris 1541.
Comme sources connectées, une tablette Samsung S4 sortant en LDAC, et un PC portable sortant sur une clé usb BT Avantree "limitée" à l'Aptx.
Dans les 2 cas de figure c'est très très bon, avantage à la S4 avec le LDAC, mais l'Aptx reste dans le coup je veux rassurer c'est nettement meilleur que du SBC.
Au départ sur le mode de fonctionnement en sortie coaxiale vers le dac Soekris, la S4 nouvellement reliée au Zen Blue était en SBC par défaut, ouh le passage en LDAC est sans appel... vers la qualité sonore plus élevée bien sûr, ça s'entend...
Sur le Soekris par comparaison avec mon PC audio sur liaison usb, le Ifi Audio tient tout à fait la route sur l'ensemble des qualités de restitution (équilibre, détail, précision, transparence, spatialisation, etc...), en étant légèrement en retrait par rapport à mon PC, le point le plus faible concernant la dynamique par comparaison. Sur des matériels plus petits le Zen Blue ne m'a pas semblé manquer de dynamique, mais ça justifie le travail que j'ai effectué sur mon PC qui alimente un gros système qui ne pardonne pas les défauts!
Le mode de sortie analogique du Zen Blue, reposant sur le travail de son dac interne à puce Sabre est convaincant. Je ne trouve pas le son quelquefois caractéristique des Sabre, l'aigu ici reste naturel et les qualités d'ensemble présentes, pour me laisser aller aux écoutes sans couper au bout d'une heure par manque de quelque chose.
L'alimentation fournie m'a irrité, j'espérais avoir la Ipower 5v pour le prix, Ifi Audio met un adaptateur beaucoup plus petit, mais ça ne semble pas impacter le résultat sonore? il faudrait que j'essaye une Ipower pour comparer...
Au total unité Bluetooth très convaincante, la qualité de restitution est là sur les 2 modes / dac interne et externe. Elle se connecte facilement aux sources, la couleur de la led à droite en façade indique sur quel codec BT on fonctionne. Pas d'interrupteur de marche-arrêt par contre.
Bluetooth de course!
Appareil superbement fini, performant, et agréable à utiliser!
Le matériel proposé par ifi-audio est de haut vol.
Excellent appareil!
D'abord le Zen Blue est très esthétique, sobre et moderne. Boitier aluminium et connexions de belle qualité. Ensuite fonctionnement très simple, appairage facile, connexions très stables. Appareil au top pour tous les différents codecs et capable de se connecter à 7 appareils. Et enfin un résultat sonore bluffant: grande dynamique, transparence, respect des timbres, veste scène sonore, met en lumière toutes les différences d'un enregistrement à l'autre. Très proche d'une qualité CD. Prix sensiblement supérieur à d'autres récepteurs Bluetooth proposés sur la toile, mais finalement justifié. A recommander vivement. (Equipement: ampli Yaquin MS500B équipé de tubes 300B Full Music, enceintes Klipsch Hérésie III, câbles Ecosse, bloc secteur Supra).
iFi Audio's Zen Blue is the first Bluetooth receiver on the market to support all the latest Hi-Res codecs, providing the best possible audio...
