Commandé le jeudi reçu la samedi :)
Ce petit boitier fait parfaitement le job, je l'ai connecté sur l'entrée spdif du lecteur Audia CD1M, la restitution est excellente au regard de l'investissement ! Mon installation B&W 805d2 DB2d - Fls9 - Cd1M
The SMSL B1 Bluetooth Audio receiver features AptX technology and allows you to enjoy high-quality wireless on your devices that do not have this basic feature. Thanks to its technology Bluetooth 4.2 aptX, there is no delay and audio delay on the devices aptX Certified Low Latency .
The SMSL B1 is equipped with a DAC Wolfson WM8524, decoding streams up to 24Bit / 192kHz. It also has a Headphone amplifier MAX97220Adriving headphones up to 32 Ohm / 65mW via its 3.5mm jack output.
Its outputRCA Stereo , and its two digital outputs Optical/Coaxialallow you a wide choice of connection to your HiFi and Home Cinema devices.
One of the special features of this Bluetooth SMSL receiver is its ability to run on battery. The latter with a capacity of 800mAh allows you to last for 12 hours in operation. It is of course possible to let it plug in permanently.
The volume button allows you toHeadphones. Theoutputs RCAthey remain fixed.
Discover the complete and detailed test of the SMSL B1 Bluetooth receiver, which has been awarded a Qobuzissime for its qualities and performance (Click on the banner below).
General specifications:
Connectivity / Dimensions / Weight:
Input | Bluetooth |
Output | RCA |
Output | Coaxial SPDIF |
Output | Optical Toslink |
Output | Jack 3.5mm |
DAC / ADC Chip | WM8524 |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Average votes 4.9 / 5 34 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Dominique G.
gilbert d.
Michel B.
LEGRAIN E.
Julien Anne B.
