WiFi Dongle 802.11n 150Mbps USB 2.0 with long distance antenna
3.0 / 5
Reference : 11713
9,90 €tax incl.
8,25 € tax excl.
This wireless USB 2.0 adapter will allow you to enjoy the quality of transmission and reception of WiFi on devices with a USB 2.0 port. It has a high transmission speed with 150Mbps and a very long operating distance thanks to its 6dB antenna.
Thist WiFi adapter is very easy to implement via the drivers CD provided with. In fact it is compatible with Windows XP, Windows Vista, Windows 7, Windows 8 and higher, but also Linux compatible for DIY and more sharp applications.
Features:/ Strong>
  • Wireless Adapter: WiFi 2.4G 802.11n
  • High transmission speed: 150Mbps
  • USB 2.0
  • Antenna 6dB: very long operating distance
  • Dimensions: 145x20x10mm (Unfolded)
  • Net Weight: 12g
  • Compatibility: Windows XP / VISTA / 7 / Windows 8 and higher / Linux
  • CD of drivers supplied with (attention it is present in the packaging, not to cut it with scissors)/ Li>
  • CE compliant
- Example of use on a laptop -
InputWiFi
OutputUSB
OutputWiFi
Transmission / Reception protocolWiFi
2 reviews
Super facile
Acheté pour capter le wifi sur un système Volumio-Raspberri Pi enfermé dans un boîtier hi-fi métallique. Un petit câble de rallonge USB et cette antenne et hop, le signal wifi est de retour (et meilleur qu’avec l’antenne du RPi) et tout cela en plug and play (pas besoin d’installer de driver).
This review has been posted for WiFi Dongle 802.11n 150Mbps USB 2.0 with long distance antenna
Not usable for Allo USBridge Signature
I bought this to enable wifi on the Allo USBridge Signature but sadly it causes incredible noise and distortion.
We just tested this Wifi adapter with Volumio, and didn't noticed any problem !?
