je l'ai depuis peu, je trouve la qualité audio bonne , il se synchronise
bien ,la qualité de fabrication est bonne , l'affichage est un plus agréable , a ce prix c'est une bonne affaire.
This product has been replaced by the new version, the XDUOO XQ-50 PRO2 Bluetooth Receiver 5.1 QCC5125.
Bluetooth Receiver 5.0 aptX-HD CS8406 DAC ES9018K2M
/>XDUOO XQ50 version PRO is a CSR8675 Bluetooth receiver with integrated SABRE ES9018 DAC and CS8406 S/PDIF interface. This solution is ideal for using your purely analog devices (preamplifier / integrated amplifier / active speakers ) with your digital sources. The connection can be wired ( USB ) and wireless (Bluetooth 5.0). It also has a digital output for use with SPDIF devices that lack a wireless connectivity.
The PRO version now has an OLED screen to display the metadata of your digital tracks during playback. It reads in real time the active input, Bluetooth protocol, track number, track name and its bitrate / sampling rate.
Very practical, qualitative and affordable, this reveiver allows you to stream your music directly from your smartphone, tablet or any other device with Bluetooth connectivity (transmitter). Its careful design allows it to offer a clean playback of your audio files.
Le XQ-50 PRO uses a Qualcomm CSR8675 bluetooth chip. This is a major upgrade since the first version since the XQ50 PRO now supports SBC, AAC, apt-X, apt-X Low Latency, apt-X HD and LDAC. Those protocols ensure fast and stable data transmission and guarantees high quality Bluetooth audio playback. A Bluetooth antenna improves the maximum transmission distance.
The receiver is also equipped with a DAC ESS SABRE ES9018K2M chip for digital-to-analog conversion. This excellent chip helps to provide the most accurate reproduction possible.
The output panel has a RCA stereo analog connector, a digitial S/PDIF and a Toslink connector. The digital output stage uses a SPDIF CS8406 interface chip. The device can also function as a USB DAC by connecting it directly via its USB-C port to a computer.
Spécifications | ||
Type | Bluetooth Receiver | |
Bluetooth | 5.0 | |
Bluetooth protocols support | SBC, AAC, apt-X, apt-X HD, apt-X Low Latency, LDAC | |
Bluetooth Chip | CSR8675 | |
Digital interface | CS8406 | |
DAC chip | ES9018K2M | |
Distance transmission | 10m | |
THD+N | Coaxial, Optical : 0.00087% RCA Stéréo : 0.07% | |
Output level | Coaxial, Optique : 0.5Vp-p RCA Stéréo : 2.5V | |
Sampling rate | Jusqu'à 24bit 44kHz | |
Power supply | 5VDC 1A via USB-C (Adaptateur 5V USB-C available) |
Input | Bluetooth |
Input | USB |
Output | RCA |
Output | Optical Toslink |
Output | Coaxial SPDIF |
DAC / ADC Chip | ES9018K2M |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Average votes 5.0 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Henri c.
Michel V.
Sébastien K.
Yannick J.
Daniel S.
