This transceiver pair allows you to transpose vox music streams analog or digital remotely.
Due to its versatility (it is able to resituate a digital flow from an analog source and vice versa) it will be able to comply with all your needs. (See explanatory diagrams below) .
Unlike most transmitters it is not the Bluetooth technology that is used here but the Wifi allows transmission of the signal without any compression or loss (CD quality).
Features:/ Strong>
- Range: 10 m in a crowded environment or 20 m in an open environment (placing them in height increases their range).
- Technology: RF 2.4 GHz
- DAC / ADC: Nordic semi conductor nRF24Z1
- Maximum PCM flow: 1.536 Mbps
- Wireless transmission at a 16bit compressionless sampling rate (32, 44.1 and 48khz)
- Hull: Aluminum case
- Dimensions: (70 x 65 x 30 mm) x 2
- Weight: (120 g) x 2
- Power supply: 5V 500mA on USB port for powering via your microcomputer + (two mains transformers supplied)/ Li>
- Inputs: 2 SPDIF digital inputs (optical and coaxial) and one stereo analog input on RCA
- Outputs: 2 SPDIF digital outputs (optical and coaxial) and an analog stereo output on RCA
![https://www.audiophonics.fr/images2/7624/7624_emt-recep_thumbs2.png](https://www.audiophonics.fr/images2/7624/7624_emt-recep_thumbs2.png)
![https://www.audiophonics.fr/images2/7624/7624_emt-recep_34.jpg](https://www.audiophonics.fr/images2/7624/7624_emt-recep_34.jpg)
![https://www.audiophonics.fr/images2/7624/7624_emt-recep_23.jpg](https://www.audiophonics.fr/images2/7624/7624_emt-recep_23.jpg)
![https://www.audiophonics.fr/images2/7624/7624_emt-recep_13.jpg](https://www.audiophonics.fr/images2/7624/7624_emt-recep_13.jpg)
Possible Usage Scenarios:
![https://www.audiophonics.fr/images2/7624/scenario_analogique_1_elecaudio-wdact-1.jpg](https://www.audiophonics.fr/images2/7624/scenario_analogique_1_elecaudio-wdact-1.jpg)
![https://www.audiophonics.fr/images2/7624/scenario_digital_2_elecaudio-wdact-1.jpg](https://www.audiophonics.fr/images2/7624/scenario_digital_2_elecaudio-wdact-1.jpg)
![https://www.audiophonics.fr/images2/7624/scenario_ana-num_3_elecaudio-wadct-1.jpg](https://www.audiophonics.fr/images2/7624/scenario_ana-num_3_elecaudio-wadct-1.jpg)
![https://www.audiophonics.fr/images2/7624/scenario_num-ana_4_elecaudio-wadct-1.jpg](https://www.audiophonics.fr/images2/7624/scenario_num-ana_4_elecaudio-wadct-1.jpg)
