très déçu par le produit : impossible de l'appairer avec mon casque JBL et votre service technique n'a pas la solution
Bluetooth Transmitter Plug & Play A2DP
This BT-TX from TinySiny will allow you to transform your Bluetooth-free music source into a transmitter. This eliminates the need for cables to send music from your source to your Bluetooth amplifier. In addition, it is equipped with a battery with an autonomy of 5-7 hours for use without power supply. Of course, it is still possible to power the unit with the supplied DC/USB Jack cable for extended use.
Installation is very simple. The device does not require the installation of any driver. Simply connect the 3.5mm Jack to your source. Then all you have to do is press the button for 3 to 5 seconds to turn on the transmitter.
Warning: It is necessary that your receiving device is Bluetooth A2DP compatible.
The first time you use the BT-TX with a device you will need to pair these. Here is the process:
Bluetooth version | 2.1+EDR |
Bluetooth Profile | A2DP |
Input | Jack 3.5mm |
Battery autonomy | 6-7 hours |
Charging time | 1.5 hours |
Dimensions | 45 x 32 x 8mm |
Weight | 14g |
Package | 1x TinySine BT-TX 1x USB-A to Jack DC Cable |
Output | Bluetooth |
DAC / ADC Chip | NC |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | N/A |
Average votes 2.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Christian E.
Yves A.
