Cable XH 2.54mm Female / Female 3-Pole No Casing 30cm
This XH 2.54mm female interconnect cable has 3 conductors. There are 3 XH2.54mm connectors without housings on each side of the cable. Its 30cm length makes it ideal for wiring complex, bulky devices, or those with a connector layout that requires a certain margin.
Reference : 19808
0,90 €tax incl.
0,75 € tax excl.
Shipping date: 22-04-2025.
Photo of XH 2.54mm cable
This XH 2.54mm female interconnect cable has 3 conductors. There are 6 XH2.54mm connectors without casing on each side of the cable. Its 30cm length makes it ideal for wiring complex, bulky devices, or those with a connector layout that requires a certain margin. This interconnect cable is ideal for the internal wiring of your DIY projects, for quick and easy connection to XHP plugs.
Product typeXH 2.54mm cable
ConnectorsXH 2.54mm female without casing
Number of conductors3
Cable length30cm
Package1x XH 2.54mm cable
Length (m)0.3
ConnecticFemale
Contacts number3
This XH 2.54mm female interconnect cable has 3 conductors. There are 3 XH2.54mm connectors without housings on each side of the...
