XH 2.54mm Cable Female / Female 12 Pins No Casing 40cm (Unit)
This XH 2.54mm Female / Female cable will allow you to make quick connections between two XH 2.54mm male connectors for your DIY projects. This one benefits from Copper conductors to ensure a very good signal conductivity.
Reference : 15039
1,70 €tax incl.
1,42 € tax excl.
Shipping date: 22-04-2025.
Nappe XH 2.54mm
Connecteur Femelle / Femelle 12 pôles 40cm (Unité)
Nappe XH 2.54mm Connecteur Femelle / Femelle 12 pôles 40cm (Unité)
The 12 cables composing this product are detachable.
Product typeXH 2.54mm female / female cable
Number of poles12 poles
Length40cm
ConductorsTinned Copper alloy
QuantitySold by unit
Length (m)0.4
ConnecticFemale
Contacts number12
This XH 2.54mm Female / Female cable will allow you to make quick connections between two XH 2.54mm male connectors for your DIY projects. This one...
