XH 2.54mm Female / Female Cable 1 Pole No Casing Gold Plated PTFE Red 30cm (x10)
Reference : 13515
2,90 €tax incl.
2,42 € tax excl.
Shipping date: 22-04-2025.
Interconnection XH Cable
XH to XH Wire / 30cm / black
This cable has XHP connector on both end.
The special feature of this model is to have a PTFE coating, an interresting material thanks to its excellent resistance to temperature, corrosion, acid, grease, oxidation, solvent, while ... providing highly reliable electrical insulation. In other words, this XH cable will be quite suitable for any application requiring a reliable wiring time and able to withstand high contraites.
15cm length makes it ideal for complex devices wiring or with a such a display of connectors that some margin is needed to work confortably.
This interconnection cable is ideal for internal wiring of your DIY projects to quickly and easily make connections to XHP sheets.
Its connectors are gold plated for excellent conductivity.
Type of connectorGold plated XH female connector
Conductor cross section21 AWG (0.4mm²)
Cable Length30cm
Cable diameter1.2mm
Amountx10 cables
Length (m)0.3
ConnecticFemale
Contacts number1
