XH 2.54mm Female to Bare wire Cable 1 Pole No Casing PTFE 30cm Black (x10)
This cable has a XHP connector on the one hand and a tinned wire at its other end. The special feature of this model is to have a PTFE coating, an interresting material thanks to its excellent resistance to temperature, corrosion, acid, grease, oxidation, solvent while providing highly reliable electrical insulation.
Reference : 17102
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 22-04-2025.
Interconnect Cable for XH
XH to Tinned Wire / 30cm / Black
Câble d'Interconnexion pour XH XH vers fil étamé / 30cm / noire
The special feature of this model is to have a PTFE coating, an interresting material thanks to its excellent resistance to temperature, corrosion, acid, grease, oxidation, solvent while providing highly reliable electrical insulation. In other words, this XH cable will be quite suitable for any application requiring a reliable wiring time and able to withstand high contraites.
30cm length makes it ideal for complex devices wiring or with a such a display of connectors that some margin is needed to work confortably.
This interconnection cable is ideal for internal wiring of your DIY projects to quickly and easily make connections to XHP sheets.
Type of connectorXH female connector
stripped cable
Conductor cross section22 AWG (0.64mm²)
Cable Length30cm
Cable diameter1.2mm
Amountx10 cables
Length (m)0.3
ConnecticFemale
Contacts number1
This cable has a XHP connector on the one hand and a tinned wire at its other end.  The special feature of this model is to have...
