XH 2.54mm Female to Bare wires Cable 1 Pole No Casing Gold Plated PTFE Black 30cm (x10)
Reference : 13179
2,70 €tax incl.
2,25 € tax excl.
Shipping date: 22-04-2025.
Interconnect Cable for XH
XH to tinned wire / 30cm / black
xh cable sheath plated PTFE (Teflon)
This cable has a XHP connector on the one hand and a tinned wire at its other end.
The special feature of this model is to have a PTFE coating, an interresting material thanks to its excellent resistance to temperature, corrosion, acid, grease, oxidation, solvent while ... providing highly reliable electrical insulation. In other words, this XH cable will be quite suitable for any application requiring a reliable wiring time and able to withstand high contraites.
30cm length makes it ideal for complex devices wiring or with a such a display of connectors that some margin is needed to work confortably.
This interconnection cable is ideal for internal wiring of your DIY projects to quickly and easily make connections to XHP sheets.
Its connector is gold plated for excellent conductivity.
Type of connectorXH male connector
stripped cable
Conductor cross section21 AWG (0.4mm²)
Cable Length30cm
Cable diameter1.2mm
Amountx10 cables
Length (m)0.3
ConnecticFemale
Contacts number1
Allez y
J' ai remplacé les fil xlr interne d' origine de mon ampli 3e audio diy par ceci, petit gap sympa... Juste faire attention car tout les fils sont noirs
This review has been posted for XH 2.54mm Female to Bare wires Cable 1 Pole No Casing Gold Plated PTFE Black 30cm (x10)
