XH 2.54mm Female to PH 2.0mm 4 Poles 2 Connectors Black 10cm (Unit)
This 10cm cable is composed of 4 wires and has on the one hand a 4 pole female XH connector and on the other hand a 4 pole female PH 2.0mm connector. This type of cable can be very useful in DIY assemblies, to connect different modules with XH and PH plugs.
Reference : 12889
2,60 €tax incl.
2,17 € tax excl.
Shipping date: 25-04-2025.
XH 2.54mm / PH 2.0mm Cable
4 poles female XH 2.54mm to 4 poles female PH 2.0mm
Câble XH vers PH
This 10cm cable is composed of 4 wires and has on the one hand a 4 pole female XH connector and on the other hand a 4 pole female PH2.0mm connector. This type of cable can be very useful in DIY assemblies, to connect different modules with XH and PH plugs.
Length10cm
ConnectorsXH 2.54mm
PH 2.0mm
Poles number4 poles
Length (m)0.1
ConnecticFemale
Contacts number2
This 10cm cable is composed of 4 wires and has on the one hand a 4 pole female XH connector and on the other hand a 4 pole female PH 2.0mm...
