3 Way Male XLR Connector Ø8mm Black (Unit)
Reference : 13226
2,90 €tax incl.
2,42 € tax excl.
Shipping date: 25-04-2025.
XLR straight connector Male
XLR male connector plug
Male XLR plug.
Completely removable with soft capsule for excellent support & impact resistance.
The insert of the cable is made of an elastic material for good mechanical stability and compatibility with the types of cables and various ducts.
TypeXLR
GenreMale
Number of cores3
Mountingsoldering
Force insertion> 20N
Insulation resistance1000MΩ
Rated current16A
Nominal voltage50V
Tension max1.5KV
Connector resistance<5mO
Max cable diameter8mm⌀
General diameter19mm⌀
Length72.55
Weight32g
Insulation materialPU
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticMale
Contacts number3
ConnectorXLR
Contacts Plating (Connector)Nickel
