AECO AMI-1060R XLR 3-Pole Male and Female Connectors Rhodium-Plated Tellurium Copper Ø12mm (Pair)
This pair of AECO AMI-1060R connectors consists of a male XLR connector and a female XLR connector. These 3-pole XLR connectors feature a "one-point contact" structure with tellurium copper contacts and PTFE insulation. They accept cables with a maximum external diameter of Ø12mm.
Reference : 18409
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 03-04-2025.
AECO AMI-1060R
This pair of AECO AMI-1060R connectors consists of a male XLR connector and a female XLR connector. These 3-pole XLR connectors feature a "one-point contact" structure with tellurium copper contacts and PTFE insulation. They accept cables with a maximum external diameter of Ø12mm, and a sleeve allows the insertion hole to be tightened to Ø8.5mm. Contacts are made of tellurium copper with Rhodium plating for corrosion and oxidation resistance, as well as enhanced conductivity.
Product typeXLR connectors
GenderMale and female
Number of contacts3 poles
COntact materialTellurium copper (Copper +99%)
Contact platingRhodium (without nickel base)
Max. cable diameterØ12mm
InsulationPTFE
Mounting typeTo weld
Contacts resistance < 1mOhm
DimensionsØ18.9 x 46 x 59.5mm
PackageSold by pair
1x Male XLR AECO AMI-1060R connector
1x Female XLR AECO AMI-1060R connector
Insulation materialPTFE
Max cable diameter (mm)12.0
ConnecticMale & Female
Contacts number3
ConnectorXLR
Contacts Material (Connector)Tellurium Copper
This pair of AECO AMI-1060R connectors consists of a male XLR connector and a female XLR...
