AECO AX4-1611S 4 Pins XLR Connector Tellurium Copper Silver Plated Ø12.5mm
The aeco AX4-1611S is a high-quality 4-pin XLR connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are made of high-purity tellurium copper with silver plating, ensuring perfect conductivity.
Reference : 18066
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 24-04-2025.
aeco AX4-1611S
The aeco AX4-1611S is a high-quality 4-pin XLR connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are made of high-purity tellurium copper with silver plating, ensuring perfect conductivity. The connector body is made of brass and the contacts are insulated with a PTFE layer. The AX4-1611S accepts cable diameters up to 12.5mm without the reducer or 8.5m with the reducer.
Produc ttypeMale 4 pins XLR connector
Contacts materialTellurium copper (purity: > 99%)
Contacts platingSilver
Insulation materialPTFE
Shell materialBrass
Max cable diameterWith reducer: Ø8.5mm
Without reducer: Ø12.5mm
Contact resistance< 1mΩ
ColorSilver
Total dimensionsØ18.9*46mm
Max cable diameter (mm)12.5
Mounting typeTo weld
ConnecticMale
Contacts number4
ConnectorXLR
The aeco AX4-1611S is a high-quality 4-pin XLR connector, designed using high-performance components for optimum transmission of the audio signal....
