AMPHENOL AX3M Male 3 Poles XLR Connector Ø8mm
The Amphenol AX3M 3-pin male XLR connector lets you make robust, professional-quality cables. Thanks to its nickel plating and body, the connector is extremely durable and corrosion-resistant. This XLR connector accepts cable diameters from 3mm to 8mm, with soldered connections.
Reference : 18905
3,60 €tax incl.
3,00 € tax excl.
Shipping date: 25-04-2025.
AMPHENOL AX3M Male 3 Poles XLR Connector Ø8mm : Front view
AMPHENOL AX3M Male 3 Poles XLR Connector Ø8mm : Dimensions
Product typeMale 3 poles XLR connector
Min/Max cable diameterØ3mm / Ø8mm
Mounting typeTo solder
Rate current per contact15A
Rated voltage133V
Lifetime> 1000 cycles
Contacts materialCopper alloy
Contacts platingNickel
Shell materialNickel
Temperature range-25°C / +75°C
Package1x Male 3 Poles XLR Connector AMPHENOL AX3M
Insulation materialNylon
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticMale
Contacts number3
ConnectorXLR
Contacts Plating (Connector)Nickel
Super
Qualité prix exceptionnel. C' est beau, ça se soudé facilement, mécanique impeccable . Restitution neutre. Meilleur que Neutrik ou équivalent?
This review has been posted for AMPHENOL AX3M Male 3 Poles XLR Connector Ø8mm
The Amphenol AX3M 3-pin male XLR connector lets you make robust, professional-quality cables. Thanks to its nickel plating and body, the connector...
