EIZZ EZ-206 XLR Gold Plated 3 Way Female XLR Connector PTFE Ø9mm Red (Unit)
This XLR EIZZ connector with PTFE insulation allows the design of XLR balanced quality cables. Its gold-plated finish and seamless screw terminal blocks ensure first-rate contact.
Reference : 12390
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 01-04-2025.
EIZZ XLR PTFE
without Soldering
This gold-plated 3-pin XLR connector with PTFE insulation features an excellent finish with screw terminals that avoid tin soldering on the hot-spot, cold-spot and ground connectors. It is therefore ideal for designing high quality AES / EBU cables.
Its 24K gold plating, its internal PTFE insulation in the background is an excellent candidate for quality cables at reasonable cost.
XLR EIZZ PTFE TEFLON
Technical caracteristics
Connecteur XLR EIZZ EZ206M
TypeXLR FEMALE
material conductorBronze Phosphorus
Insulated materialPTFE
Acceptable cable diameter8mm with clamping ring, 9mm without clamping ring
external body MaterialAluminium alloy and Chrome plated
Divers
Length and diameter52.2mm / 19mm
QuantitySold per unit
Weight26g
Insulation materialPTFE
Max cable diameter (mm)9.0
Mounting typeTo screw
Mounting typeTo weld
ConnecticFemale
Contacts number3
ConnectorXLR
2 reviews
bon produit
Connecteurs a recommander faciles a utiliser. Produit de bonne qualité.
This review has been posted for EIZZ EZ-206 XLR Gold Plated 3 Way Female XLR Connector PTFE Ø9mm Red (Unit)
Très bien
Belle connectique de qualité, ça faisait un moment sue je voulais essayer un produit sans soudure afin d'avoir "un intermédiaire" de moins, et le résultat est fructueux, sur le câble haut de gamme que j'ai dépecé (Burmester Silver) en enlevant ses prises de qualité soudées j'ai eu un petit gain for t sympathique à l'écoute :)
This XLR EIZZ connector with PTFE insulation allows the design of XLR balanced quality cables. Its gold-plated finish and seamless screw terminal...
