ELECAUDIO CX-102 Gold Plated 3 Way Female XLR Connector Ø8.5mm (Unit)
This Elecaudio CX-102 3-pin female XLR connector has a quality design with gold-plated Bronze Phosphore contacts.
4.9 / 5
Reference : 12540
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 25-04-2025.
ELECAUDIO CX-102
Female 3 pins XLR Gold plated Bronze Phosphore Ø 8.5mm (Unité)
elecaudio connecteur xlr femelle 3 pins plaqué or
This Elecaudio 3 pin female XLR connector benefits from a high quality design thanks to the use of high quality material. We thus find gold-plated Bronze Phosphore contacts ensuring good conductivity and high resistance to oxidation.
In addition, the metal structure of the connector will ensure great durability. A lug ensures the good maintenance of the connector once connected.
Connector typeFemale 3 pin XLR
Contacts materialBronze Phosphore
Contacts platingGold
Connection typeSoldering
Max. cable diameter8.5mm
Total dimensions63 x 23mm
Insulation materialPE
Max cable diameter (mm)8.5
Mounting typeTo weld
ConnecticFemale
Contacts number3
ConnectorXLR
9 reviews
excellent
tout simplement le meilleur rapport qualité prix en matière de fiche xlr.
This review has been posted for ELECAUDIO CX-102 Gold Plated 3 Way Female XLR Connector Ø8.5mm (Unit)
Super
High quality, price friendly connector.
Pas facile ces demoiselles !
Certe, c' est mon premier diy, mais je déconseille aux débutants en soudure, ce qui est mon cas.
Il faut savoir souder vite au risque de voir les pattes de fixation se désolidariser du châssis en plastique.
Sinon, elles sont jolies et fonctionnelles.
very good product
Paul
Hi , nice plugs and easy to solder . Thank you
