ETI BRIO XLR Female 3-Pole Connector Rhodium-Plated Tellurium Copper Ø12mm (Pair)
This XLR 3-pin female ETI BRIO connector is a top-of-the-range connector designed with top-quality components. The contacts are made of Rhodium-plated Tellurium copper for increased conductivity and resistance to oxidation and corrosion.
Reference : 18420
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 24-04-2025.
ETI BRIO Connecteur XLR
ETI BRIO XLR Female 3-Pole Connector Rhodium-Plated Tellurium Copper Ø12mm Red (Unit)
This XLR 3-pin female ETI Brio connector is a top-of-the-range connector designed with top-quality components. The contacts are made of rhodium-plated tellurium copper for increased conductivity and resistance to oxidation and corrosion.
In this connector, ETI has corrected a recurring problem in many XLR connectors on the market, namely too much ground causing higher capacitance, which affects sound. The brand has also studied the question of pin thickness. The result of this research is that the best thickness for low-voltage connectors is 0.6mm. A greater or lesser thickness would have a negative effect on reproduction quality.
For the connector body, ETI uses brass and a PTFE dielectric insulator, a structure that not only reduces vibration but also rejects EMI/RF interference.
Technical Characteristics
Product typeXLR Connector
Connector genderFemale
Pole number3
Contacts materialTellurium copper
Contacts platingRhodium
Body materialBrass
InsulationPTFE
Max. length63mm
Max. diameterØ20mm
Mounting typeTo weld
Max. cable diameterØ12mm or Ø8.5mm with reducer
ColorGrey
Weight60g
Package1x 3-pin XLR female connector red ring
1x 3-pin XLR female connector white ring
Insulation materialPTFE
Max cable diameter (mm)12.0
ConnecticFemale
Contacts number3
ConnectorXLR
Contacts Material (Connector)Tellurium Copper
This XLR 3-pin female ETI BRIO connector is a top-of-the-range connector designed with top-quality components. The contacts are...
