ETI BRIO XLR Male 3-Pole Connector Rhodium-Plated Tellurium Copper Ø12mm (Pair)
This XLR 3-pin male ETI BRIO connector is a top-of-the-range connector designed with top-quality components. The contacts are made of Rhodium-plated Tellurium copper for increased conductivity and resistance to oxidation and corrosion.
Reference : 18422
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 23-04-2025.
ETI BRIO Connecteur XLR
ETI BRIO XLR Male 3-Pole Connector Rhodium-Plated Tellurium Copper Ø12mm Red (Unit)
This XLR 3-pin male ETI Brio connector is a top-of-the-range connector designed with top-quality components. The contacts are made of rhodium-plated tellurium copper for increased conductivity and resistance to oxidation and corrosion.
In this connector, ETI has corrected a recurring problem in many XLR connectors on the market, namely too much ground causing higher capacitance, which affects sound. The brand has also studied the question of pin thickness. The result of this research is that the best thickness for low-voltage connectors is 0.6mm. A greater or lesser thickness would have a negative effect on reproduction quality.
For the connector body, ETI uses brass and a PTFE dielectric insulator, a structure that not only reduces vibration but also rejects EMI/RF interference.
Technical Characteristics
Product typeXLR Connector
Connector genderFemale
Pole number3
Contacts materialTellurium copper
Contacts platingRhodium
Body materialBrass
InsulationPTFE
Max. length50mm
Max. diameterØ20mm
Mounting typeTo weld
Max. cable diameterØ12mm or Ø8.5mm with reducer
ColorGrey
Weight50g
Package1x 3-pin XLR male connector red ring
1x 3-pin XLR male connector white ring
Insulation materialPTFE
Max cable diameter (mm)12.0
ConnecticMale
Contacts number3
ConnectorXLR
Contacts Material (Connector)Tellurium Copper
This XLR 3-pin male ETI BRIO connector is a top-of-the-range connector designed with top-quality components. The...
