ETI KRYO Silver Plated Tellurium Copper 3 Way Female XLR Connector Ø12mm (Pair)
These ETI Kryo are high-end XLR female connectors designed with exceptional components. There are Tellurium Copper contacts with Silver plating for maximum conductivity and durability.
Reference : 12793
139,00 €tax incl.
115,83 € tax excl.
XLR Connector ETI KRYO
Female XLR Connector Silver Plated Tellurium Copper ⌀20x50mm (Pair)
ETI KRYO XLR Cuivre Tellurium Plaqué Argent
In this connector, ETI corrects a recurrent problem in many XLR connectors on the market, namely a too large mass causing a higher capacitance altering the sound. The brand also studied the question of pine thickness. From this research results that the best thickness for low voltage connectors is 0.6mm. A more or less important thickness would act negatively on the quality of restitution.
For the connector body, ETI uses Brass and Teflon dielectric insulation, this structure reduces vibration but also repels EMI / RF interference.
The connector also receives cryogenic treatment in the USA, giving it even higher performance.
Conductor materialTellurium Copper
PlatingSilver
Housing materialBrass
InsulationTeflon
Max length63mm
Max diameter20mm
Connection typeTo solder
Max cable diameterWith reducer : 8.5mm
Without reducer : 12.5mm
Package1x Female XLR connector with white ring
1x Female XLR connector with red ring
Insulation materialPTFE
Max cable diameter (mm)12.5
Mounting typeTo weld
ConnecticFemale
Contacts number3
ConnectorXLR
Contacts Material (Connector)Tellurium Copper
4 reviews
Très bons connecteurs XLR
Après avoir changé mon intégré Marantz Amp1 par un couple Audio GD A1 et DAC Matrix X-Sabre PRO MQA, j'avais câblé les enceintes sur des fiches bananes ETI KRYO qui me donnent toute satisfaction. J'ai acheté quatre fiches ETI KRYO XLR (deux noires et deux rouges en male et femelle) , pour relier le DAC et l'ampli.
Les fiches à l'arrière de l'Audio GD sont homogènes et l'ensemble fonctionne bien avec une amélioration du son sensible après rodage.
J'écoute principalement des fichiers audio issus de Qobuz, avec un rééchantillonnage en DSD 64 qui est particulièrement agréable avec Audivarna et le DAC Matrix. Le câble USB est un OYAIDE Continental 5S également pris chez Audiophonics (décidément) et qui est aussi de très haute qualité.
Au niveau montage, j'ai fait câbler ces fiches avec un câble NEOTECH NEI-2001 soudé avec de la soudure MUNDORF SUPREME Étain à Souder Soudure Argent 10%. Rien de spécial à signaler (je travaille avec un artisan qui est un excellent soudeur et qui a fait le travail pour moi). Le schéma de câblage n'est pas fourni mais se trouve facilement sur internet.
A l'écoute : aucun problème à signaler sauf nécessité de quelques dizaines d'heure de rodage.
This review has been posted for ETI KRYO Silver Plated Tellurium Copper 3 Way Female XLR Connector Ø12mm (Pair)
Très bien
Connecteur haut de gamme pas agressif mais laisse passer le son du câble
très bon connecteur
Rien a redire ca sent le haut de gamme
mechanical issues
Same thing here. I bought them but still the same issue. The mechanical design is weak: to block the cable there is a simple screw that punches the cable and risks to break the internal wiring.
These ETI Kryo are high-end XLR female connectors designed with exceptional components. There are Tellurium Copper contacts with Silver plating for...
