ETI KRYO Silver Plated Tellurium Copper 3 Way Male XLR Connector Ø12mm (Pair)
These ETI Kryos are high-end XLR connectors designed with exceptional components. There are Tellurium Copper contacts with Silver plating for maximum conductivity and durability.
Reference : 12790
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 29-04-2025.
XLR Connector ETI KRYO
Silver plated Tellurium Copper ⌀20x50mm (Pair)
ETI KRYO XLR Cuivre Tellurium Plaqué Argent
In this connector, ETI corrects a recurrent problem in many XLR connectors on the market, namely a too large mass causing a higher capacitance altering the sound. The brand also studied the question of pine thickness. From this research results that the best thickness for low voltage connectors is 0.6mm. A more or less important thickness would act negatively on the quality of restitution.
For the connector body, ETI uses Brass and Teflon dielectric insulation, this structure reduces vibration but also repels EMI / RF interference.
The connector also receives cryogenic treatment in the USA, giving it even higher performance.
Conductor materialTellurium Copper
PlatingSilver
Housing materialBrass
InsulationTeflon
Max length50mm
Max diameter20mm
Connection typeTo solder
Max cable diameterWith reducer ring : 8.5mm
Without reducer ring : 12.5mm
Package1x XLR Male connector with red ring
1x XLR Male connector with white ring
Insulation materialPTFE
Max cable diameter (mm)12.5
Mounting typeTo weld
ConnecticMale
Contacts number3
ConnectorXLR
Contacts Material (Connector)Tellurium Copper
ETI KRYO Connecteur XLR Mâle 3 Pôles
Aussi incroyable que cela puisse puisse paraitre à l'écoute, ce Connecteur XLR est de loin le plus musicale que j'ai branché sur mon installation. Depuis les ancestrales Neutrik en passant par Furutech et consort , la technique ETI KRIO c'est du très niveau la soudure est facile, l'isolation en téflon supporte aisément la température de la panne du fer à souder . Un peu cher mais le résultat est au rendez vous .Hautement conseillé pour les audiophiles et les mélomanes
This review has been posted for ETI KRYO Silver Plated Tellurium Copper 3 Way Male XLR Connector Ø12mm (Pair)
These ETI Kryos are high-end XLR connectors designed with exceptional components. There are Tellurium Copper contacts with Silver plating for...
