ETI LINK XLR Connector Gold Plated Tellurium Copper Ø9mm (Set x4)
The ETI Link XLR connector has been designed with high-end materials to offer the best possible transmission performance. Its contacts are made of Tellurium Copper, ensuring excellent conductivity and durability. The contacts are also gold plated, without the use of nickel, to maintain perfect signal transmission.
3.0 / 5
By buying this product you get 20 loyalty points
Reference : 15502
209,00 €tax incl.
174,17 € tax excl.
Shipping date: 23-04-2025.
ETI LINK XLR
ETI Link XLR Connecteur XLR Cuivre Tellurium Plaqué Or Ø9mm (Set x4)
The body of the connector is made of Aluminum, allowing to reject EMI and RF interferences that could generate noise. Two screws ensure a perfect hold of your cable while protecting it from the mechanical constraints to which it could be exposed.
Product typeXLR Connectors
Connectors2x Male XLR
2x Female XLR
ContactsTellurium Copper
Contacts platingGold
BodyAnodized aluminum
QuantitySold by 4 units :
1x Male XLR connector with red ring
1x Male XLR connector with white ring
1x Female XLR connector with red ring
1x Female XLR connector with white ring
Insulation materialNC
Max cable diameter (mm)9.0
Mounting typeTo screw
ConnecticMale & Female
Contacts number3
ConnectorXLR
Contacts Material (Connector)Tellurium Copper
Dommage !!
Difficile a souder.
Pourquoi concevoir des pins aussi épais, qui nécessitent d être chauffés et un corps plastique qui ne résiste pas à la chauffe ?
Pour un câble de petite section ou multibrin pourquoi pas mais sinon, mieux vaut aller ailleurs.
This review has been posted for ETI LINK XLR Connector Gold Plated Tellurium Copper Ø9mm (Set x4)
The ETI Link XLR connector has been designed with high-end materials to offer the best possible transmission performance. Its contacts are made of...
