ETI NEXUS Silver Plated Tellurium Copper Male 3 Poles XLR Connector Ø8.5mm (Pair)
Nexus ETI XLR connectors offer a very good design quality, integrating copper machined contacts with a small quantity of Tellurium. In addition, there is a silver plating of the contacts.
0.0 / 5
Reference : 13805
129,00 €tax incl.
107,50 € tax excl.
ETI NEXUS XLR
ETI NEXUS XLR Connecteur XLR 3 pôles mâle (La paire)
Nexus ETI XLR connectors offer a very good design quality, integrating copper machined contacts with a small quantity of Tellurium. In addition, there is a silver plating of the contacts. This combination ensures both an excellent signal transmission and a very good contact durability. Mounting is extremely simple, the conductors of your cable can be screwed directly to the XLR connector contacts. The connector accepts cables up to 8.5mm.
Product typeMale XLR connectors
Poles number3
Conductor materialTellurium Copper
Contacts platingSilver
Max cable diameterØ8.5mm
Connection typeTo screw
QuantitySold per pair (1 connector with red ring, 1 connector with white ring)
Insulation materialPU
Max cable diameter (mm)8.5
Mounting typeTo screw
ConnecticMale
Contacts number3
ConnectorXLR
Contacts Material (Connector)Tellurium Copper
mechanical issues
The mechanical design is weak: to block the cable there is a simple screw that punches the cable and risks to break the internal wiring. Go Neutrik or Furutech, it is wasted money to use this.
This review has been posted for ETI NEXUS Silver Plated Tellurium Copper Male 3 Poles XLR Connector Ø8.5mm (Pair)
Nexus ETI XLR connectors offer a very good design quality, integrating copper machined contacts with a small quantity of Tellurium. In addition,...
