Female XLR Connector 3 Pins Ø8mm Black
This high quality female XLR connector will allow you to design your own audio cables. Robust, it benefits from a black metal body with a red ring. It also accepts cables up to 8mm in diameter.
Reference : 16753
3,50 €tax incl.
2,92 € tax excl.
XLR Connector
3 Pins Female Ø8mm
Connecteur XLR 3 Pôles femelle Ø8mm
Product typeFemale XLR connector
Number of pins3
Body materialMetal
Max cable diameterØ8mm
Mounting typeTo solder
ColorBlack with red ring
Total dimensionsØ21 x 57mm
Insulation materialNC
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticFemale
Contacts number3
ConnectorXLR
This high quality female XLR connector will allow you to design your own audio cables. Robust, it benefits from a black metal body with a red ring....
