FURUTECH CF-602F NCF Female XLR Connector Rhodium Plated Copper NCF Alpha Process Ø10mm
Furutech introduces the CF-601M NCF high-end XLR connector. This is Furutech's first high-performance balanced signal connector to feature Nano Crystal² Formula (NCF) material. NCF is the cumulative result of more than 30 years of work by the brand to eliminate electrical and mechanical resonance from signal and power transmission in audio and video applications. Offering noise reduction, sound image enhancement, and complete neutrality, the CF-601M NCF will allow you to design high-end audio cables to get the most out of your system and your music.
By buying this product you get 36 loyalty points
Reference : 16708
189,00 €tax incl.
157,50 € tax excl.
Shipping date: 25-04-2025.
Furutech CF-602F NCF
Female XLR Connector Rhodium Plated Copper NCF Alpha Treatment Ø10mm
Furutech CF-602F NCF Connecteur XLR Femelle Cuivre Plaqué Rhodium NCF Traitement Alpha Ø10mm
Furutech introduces the CF-602F NCF high-end XLR connector. This is Furutech's first high-performance balanced signal connector to feature Nano Crystal² Formula (NCF) material. NCF is the cumulative result of more than 30 years of work by the brand to eliminate electrical and mechanical resonance from signal and power transmission in audio and video applications. Offering noise reduction, sound image enhancement, and complete neutrality, the CF-602F NCF will allow you to design high-end audio cables to get the most out of your system and your music.
Nano Crystal² Formula (NCF) body
The CF-601m NCF uses a body design that incorporates NCF material. This resin contains nylon, fiberglass, piezoelectric ceramic particles, carbon powder to make the ultimate damping material. This is injected into the rhodium-plated copper contacts and treated α (alpha).
Used in some Furutech products, NCF is a special crystalline material with "active" properties. First, it generates negative ions that eliminate static electricity. Secondly, it converts thermal energy into far infrared. Furutech combines this material with nanometric ceramic particles and carbon powder for their piezoelectric damping properties.
Cryogenic and demagnetization α (Alpha) process
Using state-of-the-art technology and materials, Furutech has developed a two-step process that significantly improves the performance of the conductive material. The treatment starts during the manufacturing process with a deep cryogenic step of all metal parts. Using refrigerants such as liquid N2 or He, Furutech reaches temperatures between -196°C and -250°C. The treated parts change their molecular structure, relieving internal stresses. The molecules bond more tightly together, and the overall structure becomes more stable. This results in improved electrical conductivity for better signal transmission.
The second step of the process exposes these same parts to the patented demagnetization treatment, optimized to act on the entire material and further improve conductivity.
Product typeFemale XLR connector
Conductors materialPure copper, NCF injection
Contacts platingRhodium
Process for metal partsα (Alpha)
Body materialNCF Resin
Stainless steel
MountingTo screw or solder
Max cable diameterØ10mm
Max conductors sectionBraided conductors : 2.62mm² (13AWG)
Solid conductors : 3.3mm² (12AWG)
Max conductors diameterØ2.4mm
Recommended tightening torquesConductors mounting screws : 25cN•m (2.55kgf-cm)
Body fixing screws : 30cN•m (3.06kgf-cm)
Max solder temperature~ 425°C (15s max.)
DimensionsØ18.6 x 70.85mm
Weight58.2g
ConditioningUnit
Insulation materialNC
Max cable diameter (mm)10.0
Mounting typeTo screw
Mounting typeTo weld
ConnecticFemale
Contacts number3
ConnectorXLR
Furutech introduces the CF-601M NCF high-end XLR connector. This is Furutech's first high-performance balanced signal connector to feature...
