FURUTECH FP-601M (G) Gold Plated 3 Way Male XLR Connector Ø12mm (Unit)
By buying this product you get 27 loyalty points
Reference : 5887
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 25-04-2025.
High-performance male XLR plug to be welded, with 24k gold-plated contacts. Central conductor Beryllium copper and phosphor bronze treated by the proprietary antimagnetic process FURUTECH Alpha α.
The Alpha technology involves 2 steps:
1-Cryogenization of metals by -250 ° C with the aid of liquid nitrogen in order to consolidate their molecular structure and to improve their conductivity significantly.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled so as to leave no residual magnetic at the end of the treatment.
Copper alloy body and Teflon insulation whose mouth is provided can receive cables with a maximum diameter of 12 mm.
Features:/ Strong>
  • Contacts Beryllium Copper and Phosphorus BronzePlated Gold 24k
  • Anti-magnetism treatment FURUTECH Alpha α .
  • Insulated body in copper alloy
  • Plugto Weld
  • Compatible with Diameter 12mm Maximum
  • Body Length:48.5mm
  • Body Diameter:/ Strong>19.5mm
FURUTECH FP-601M
Insulation materialPE
Max cable diameter (mm)12.0
Mounting typeTo weld
ConnecticMale
Contacts number3
ConnectorXLR
Contacts Material (Connector)Beryllium Copper
Respire la qualité furutech
Oui, c'est un produit qui n'est pas bon marché mais j'ai gagné en clarté par rapport aux fiches 701 et 702, si vous le pouvez, n'hésitez pas à changer.
This review has been posted for FURUTECH FP-601M (G) Gold Plated 3 Way Male XLR Connector Ø12mm (Unit)
