FURUTECH FP-705M (R) Rhodium Plated 4 Way Male XLR Connector Ø9mm (Unit)
Reference : 10943
37,90 €tax incl.
31,58 € tax excl.
Shipping date: 22-04-2025.
Here is a 4LIN male high performance XLR plug with Rhodium plated contacts. Central conductor made of Beryllium copper treated with the proprietary antimagnetic method FURUTECH Alpha α.
Insulated fiberglass body / PBT whose mouth is designed to receive cables with a maximum diameter of 9 mm.
Features:/ Strong>
  • contactsPlated Rhodium
  • Anti-magnetism treatment FURUTECH Alpha α
  • Copper alloy conductor
  • Insulated fiberglass body / PBT
  • Plugto Weld
  • 4 PIN
  • Compatible with Diameter 9mm Maximum
  • Length: 63.2mm
  • Diameter: 18.8 mm ± 0.1 mm
  • Black color
Insulation materialPE
Max cable diameter (mm)9.0
Mounting typeTo weld
ConnecticMale
Contacts number4
ConnectorXLR
3 reviews
Top
Qualité de fabrication et rendu sonore au top
This review has been posted for FURUTECH FP-705M (R) Rhodium Plated 4 Way Male XLR Connector Ø9mm (Unit)
High Quality product
Japanese quality, french efficiency
If you need to use a 4 pin male XLR, then you have few chances: Furutech Fp705m will be the absolute winner. Go for it, you will never regret!
