Gold Plated 3 Pins Male Mini XLR Connector Ø5mm (Unit)
This Mini XLR 3-pin male connector allows the design of cables mainly used for the connection of certain headsets (AKG for example). Its gold-plated copper contacts ensure a very good conductivity of the audio signal.
Reference : 13607
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 16-04-2025.
Mini XLR Connector
Connecteur Mini XLR 3 Pins Mâle Plaqué Or Ø5mm (Unité)
This Mini XLR 3-pin male connector allows the design of cables mainly used for the connection of certain headsets (AKG for example). Its gold-plated copper contacts ensure a very good conductivity of the audio signal. The connector accepts cables between 2mm and 5mm in diameter. The rubber tip improves resistance to twisting for greater durability. The connector body benefits from a matt Chrome surface treatment.
Product typeMale Mini XLR Connector
Number of pins3
Contacts materialCopper
Contacts platingGold
Acceptable cable diameter2 to 5mm
Connection typeTo solder
Connector housing treatmentChrome mat
Total dimensions53 x Ø10.65mm
Insulation materialPE
Max cable diameter (mm)5.0
Mounting typeTo weld
ConnecticMale
Contacts number3
ConnectorMini XLR
This Mini XLR 3-pin male connector allows the design of cables mainly used for the connection of certain headsets (AKG for example). Its...
