Gold Plated 3 Way Male XLR Connector Ø8mm Silver (Unit)
Reference : 13224
3,50 €tax incl.
2,92 € tax excl.
Shipping date: 22-04-2025.
XLR Male straight x1
XLR male connector plug
XLR plug with gold plated conductors.
Completely removable with soft capsule for excellent support & impact resistance.
The insert of the cable is made of an elastic material for good mechanical stability and compatibility with the types of cables and various ducts.
TypeXLR
GenreMale
Number of cores3
Mountingsoldering
conductive materialgold plated
Force insertion> 20N
Insulation resistance1000MΩ
Rated current16A
Nominal voltage50V
Tension max1.5KV
Connector resistance<5mO
Max cable diameter8mm⌀
ColorSilver
General diameter19mm⌀
Length72.55
Weight32g
Insulation materialPU
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticMale
Contacts number3
ConnectorXLR
Fiche conforme à la description, belle qualité de l'article, entrent parfaitement dans les connecteurs de mon ampli. Bon service,merci.
This review has been posted for Gold Plated 3 Way Male XLR Connector Ø8mm Silver (Unit)
