HICON HI-X3CF-HD-B 3-pole female XLR connector Ø6.5mm (Unit)
This HICON Hi-X3FC-HD-B XLR connector is a female XLR connector ideal for outdoor conditions. This connector is water and dust resistant according to the IP67 standard. The connector's three poles are made of gold-plated copper alloy contacts for optimum conductivity and resistance to corrosion and oxidation.
Reference : 18850
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 25-04-2025.
HICON HI-X3CF-HD-B 3-pole Female XLR Connector Ø6.5mm (Unit)
Photo of HICON HI-X3CF-HD-B connector
This HICON Hi-X3FC-HD-B XLR connector is a female XLR connector ideal for outdoor conditions. This connector is water and dust resistant according to the IP67 standard. The connector's three poles are made of gold-plated copper alloy contacts for optimum conductivity and resistance to corrosion and oxidation. This female XLR connector accepts cables up to Ø6.5mm in diameter. It features an internal lamellar-joint cable clamp for uniform pressure distribution on the cable without causing any deformation. Here are the main advantages of the Hicon Hi-X3FC-HD-B XLR connector:
  • Resistant to water, dust and dirt
  • Dust-tight and moisture-proof (IP67) when connected
  • Ergonomic design for easy connection and handling
  • High coupling cycle thanks to intelligent locking mechanism
  • Gold-plated contacts
Dimensions of the HICON HI-X3CF-HD-B connector
Product typeXLR connectors
GenreFemale
Number of poles3
Contact materialCopper alloy
Contact platingGold
Max. cable diameter6.5mm
Min. cable diameter4.6mm
Mounting typeTo weld
Protection standardIP67
Contact resistance≤ 3mΩ (inner)
Dielectric resistance1.5kVdc
Insulation resistance>5GΩ (initial)
Nominal current per contact15A
Nominal voltage125VAC
Total dimensionsØ21.5 x 79.1mm
Package1x HICON HI-X3CF-HD-B 3-pin XLR female connector
Insulation materialNC
Max cable diameter (mm)6.5
ConnecticFemale
Contacts number3
ConnectorXLR
This HICON Hi-X3FC-HD-B XLR connector is a female XLR connector ideal for outdoor conditions. This connector is water and dust resistant according...
