HICON HI-XMCF5 Mini-XLR Female 5-pin Connector
The HICON HI-XMCF5 5-pin mini-XLR female connector is a reliable, affordable connector with gold-plated contacts.
Reference : 18595
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 23-04-2025.
HICON HI-XMCF5 Mini-XLR Female 5-pin Connector Ø3.5mm (Unit)
Photo of HICON HI-XMCF5 mini-XLR connector
The HICON HI-XMCF5 5-pin mini-XLR female connector is a reliable, affordable connector with gold-plated contacts. This connector accepts cables with a diameter of Ø3.5mm. This type of connector is used to create DIY cables for specific product applications. Hicon HI-XMCF5 connectors have a simple structure and are mounted by soldering.
XLR 5-pin wiring example
HICON HI-XMCF5 wiring diagram
Product typeMini XLR connector
GenreFemale
Pole numbers5
Body materialMetal
Conductor materialCopper alloy
Contact platingGold
Max. cable diameterØ3.5mm
Mounting typeÀ souder
Total dimensions47 x Ø11mm
Package1x HICON HI-XMCF5 5-pin mini-xlr female connector
Insulation materialNC
Max cable diameter (mm)3.5
Mounting typeTo weld
ConnecticFemale
Contacts number5
ConnectorMini XLR
