Male 3 Pins Ø8mm
This high quality male XLR connector will allow you to design your own audio cables. Robust, it benefits from a zinc alloy body. It also accepts cables up to 8mm in diameter.
Product type | Male XLR connector |
Number of pins | 3 |
Body material | Zinc alloy |
Max cable diameter | Ø8mm |
Mouting type | To solder |
Color | Silver |
Total dimensions | 66 x Ø19mm |
Insulation material | NC |
Max cable diameter (mm) | 8.0 |
Mounting type | To weld |
Connectic | Male |
Contacts number | 3 |
Connector | XLR |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | None |
