NEUTRIK NC3FM-C 3 Way Unisex XLR Connector Ø8mm (Unit)
Reference : 11956
13,90 €tax incl.
11,58 € tax excl.
Integrating in the range convertCONfrom SwitzerlandNeutrik, theXLR connector NC3FM-Csurprised by its practicality. In fact, it is both a male and female connector, allowing you to adapt it to your different audio systems. Thus, the transition between the two types of plugs is done by simply sliding the connector body.
TECHNICAL CHARACTERISTICS
  • XLR Unisex: male and female position switchable.
  • 3-pole connector.
  • Accepts cable diameters from 3.5mm to 8.0mm.
  • Bronze contacts.
  • Nickel body
  • Black color
Neutrik NC3FM-C Connecteur XLR Unisexe
Insulation materialPE
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticMale & Female
Contacts number3
ConnectorXLR
Contacts Plating (Connector)Nickel
