NEUTRIK NC3FRX XLR Female 3-Pole Connector 90° Angled Silver-Plated Ø8mm (Unit)
This Neutrik NC3FRX RX series connector is a 90° angled female XLR connector. It features a nickel-plated copper alloy body and silver-plated copper alloy connectors for protection against corrosion and oxidation. It accepts cables with a minimum external diameter of Ø3.5mm to a maximum of Ø8mm. Cable assembly is performed by soldering with conductors of up to 2.5mm² (14AWG) cross-section, while overall connector assembly requires no screws for added convenience.
Reference : 18404
9,50 €tax incl.
7,92 € tax excl.
Shipping date: 24-04-2025.
NEUTRIK NC3FRX
NEUTRIK NC3FRX XLR Female 3-Pole 90° angled Silver-plated connector Ø8mm (Unit)
This Neutrik NC3FRX RX series connector is a 90° angled female XLR connector. It features a nickel-plated copper alloy body and silver-plated copper alloy connectors for protection against corrosion and oxidation. It accepts cables with a minimum external diameter of Ø3.5mm to a maximum of Ø8mm. Cable assembly is performed by soldering with conductors of up to 2.5mm² (14AWG) cross-section, while overall connector assembly requires no screws for added convenience. In addition to convenient assembly, 5 cable outlet positions are selectable. This high-quality female XLR connector also features a highly effective cable clamp, a solid metal snap-lock, solder barriers on its internal contacts and low resistance on its external contacts for enhanced conductivity. Grounding is also optimized thanks to spring-loaded contacts ensuring continuity with the connector body.
Product type90° XLR female connector
Capacitance between contacts≤ 4 pF
Contacts resistance≤ 3mΩ
Dielectric strength1.5kVcc
Insulation resistance> 2GΩ (initial)
Rated current per contact16A
Rated voltage< 50V
Min/max eternal cable diameterØ3.5 to Ø8mm
Max. cable cross-section2.5mm² (14AWG)
Mounting typeTo weld
Body materialCopper alloy
Body platingNickel
Contacts materialCopper alloy
Contacts platingSilver (2µm)
Operating temp.-30 °C to +80 °C
Total dimensions72.9 x 41 Ø15.8mm
Weight54g
Package1x NEUTRIK NC3FRX Female 3-pole 90° angled XLR connector
Insulation materialPolyurethane (PUR)
Max cable diameter (mm)8.0
ConnecticFemale
Contacts number3
ConnectorXLR
This Neutrik NC3FRX RX series connector is a 90° angled female XLR connector. It features...
