NEUTRIK NC3FXX-HA Female XLR Connector
Neutrik's NC3DXX-HA XLR female connector features a robust design with low contact resistance. The connector has an additional spring-loaded earth contact for extra safety and a nickel-plated die-cast zinc body for extra durability. It's also worth noting that assembly involves no soldering and is done by crimping.
Reference : 19307
4,50 €tax incl.
3,75 € tax excl.
Shipping date: 24-04-2025.
NEUTRIK NC3FXX-HA Female 3-Way XLR connector Ø8mm
NEUTRIK NC3FXX-HA : 3/4 view
NEUTRIK NC3FXX-HA : Dimensions
Product typeXLR female connector
Contacts materialCopper alloy
Body materialNickel-plated zinc
Minimum/maximum cable outer diameter3.5 - 8.0 mm
Minimum/maximum cable cross-section0.22 - 0.34 mm² / 24 - 22 AWG
Body length73.5mm
Body diameterØ19.2mm
Locking deviceLatch
PackageSold by unit
Insulation materialPolyurethane (PUR)
Max cable diameter (mm)8.0
Mounting typeTo crimp
ConnecticFemale
Contacts number3
ConnectorXLR
NEUTRIK NC3FXX-HA Female 3-Way XLR Connector Ø8mm
Neutrik's NC3DXX-HA XLR female connector features a robust design with low contact resistance. The connector has an additional spring-loaded...
