NEUTRIK NC3MX-BAG 3 Way Male XLR Connector Silver Plated Ø8mm (Unit)
This 3-pin XLR male Neutrik NC3MX-BAG connector allows quick and easy assembly, consisting of only 4 pieces and no screws. It benefits from a compact design, a sturdy Zinc shell and a cable clamping system ensuring a perfect fit and limiting mechanical stress on the cable. The connector contacts are made of a silver-plated copper alloy, ensuring excellent signal conductivity.
Reference : 14622
4,20 €tax incl.
3,50 € tax excl.
Shipping date: 16-04-2025.
Neutrik NC3MX-BAG
Neutrik NC3MX-BAG Connecteur XLR Mâle 3 Pôles Plaqué Argent Ø8mm (Unité)
The rear of the Polyurethane connector meets the flexibility requirements it will have to meet, depending on the assembly assigned to it.
Neutrik NC3MX-BAG Connecteur XLR Mâle 3 Pôles Plaqué Argent Ø8mm (Unité) Neutrik NC3MX-BAG Connecteur XLR Mâle 3 Pôles Plaqué Argent Ø8mm (Unité)
Product typeMale XLR connector
Number of poles3
Contacts materialCopper alloy
Contacts platingSilver 2µm
Body materialZinc
Polyurethan
Polyamide
Polyacetal (POM)
Mounting typeTo solder
Capacitance between contacts≤ 4pF
Contact resistance≤ 3mΩ
Dielectric strength1.5kVdc
Insulation resistance> 10GΩ (initial)
Rated current per contact16A
Rated voltage< 50V
Min/Max Cable diameterØ3.5mm / Ø8mm
Insertion force≤ 20N
Withdrawal force≤ 20N
Lifetime> 1000 cycles
Max cable section2.5mm² (14AWG)
Temperature range-30°C / 80°C
Approvals / StandardsUL 94 HB
IEC 61076-2-103
IP40
IEC 68-2-20
Insulation materialNC
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticMale
Contacts number3
ConnectorXLR
2 reviews
bonne prise
parfait contact, pas de defaut
This review has been posted for NEUTRIK NC3MX-BAG 3 Way Male XLR Connector Silver Plated Ø8mm (Unit)
Très bien
Comme sa version femelle, bonne fiche qualitative et neutre .
This 3-pin XLR male Neutrik NC3MX-BAG connector allows quick and easy assembly, consisting of only 4 pieces and no screws. It benefits from a...
