NEUTRIK NC3MX1-TOP Gold-Plated XLR Male 3-Pole Connector Outdoor Compatible IP65 Ø8mm
This Neutrik NC3MX1-TOP 3-pin male XLR connector is a robust connector with gold-plated copper alloy contacts. This XLR connector benefits from IP65 certification, so it's protected against dust and solid-body intrusion, and has an advanced level of water resistance. This enables the connector to operate in outdoor environments.
Reference : 18407
10,90 €tax incl.
9,08 € tax excl.
Shipping date: 24-04-2025.
NEUTRIK NC3MX1-TOP
 Gold-plated XLR Male 3-Pole Connector Outdoor Compatible IP65 Ø8mm
NEUTRIK NC3MX1-TOP Gold-plated XLR Male 3-Pole Connector Outdoor Compatible IP65 Ø8mm
This Neutrik NC3MX1-TOP 3-pin male XLR connector is a robust connector with gold-plated copper alloy contacts. This XLR connector benefits from IP65 certification, so it's protected against dust and solid-body intrusion, and has an advanced level of water resistance. This enables the connector to operate in outdoor environments, on condition that the accompanying cable meets the same specifications.
This XLR connector accepts cables with external diameters from Ø5mm to Ø8mm. Mounting of the connectors is by solder, and the maximum cross-section must not exceed 1.5mm² (16AWG).
Product typeXLR male connector
Number of contacts3 pins
Capacitance between contacts≤ 4 pF
Contact resistance≤ 3mΩ
Dielectric strength1.5kVcc
Insulation resistance> 10GΩ (initial)
Rated current per contact16A
Rated voltage< 50V
Max. external cable diameterØ5-Ø8mm
Max conductors cross-section1.5mm² (16AWG)
Mounting typeTo weld
Contacts materialCopper alloy
Contact platingGold
Body materialStainless steel
Protection classIP65, UL50E enclosure type 4
Operating temperature-30°C to +80°C
Total dimensions61-64 x Ø22.52mm
Package1x NEUTRIK NC3MX1-TOP
Insulation materialNC
Max cable diameter (mm)8.0
ConnecticMale
Contacts number3
ConnectorXLR
This Neutrik NC3MX1-TOP 3-pin male XLR connector is a robust connector with gold-plated copper alloy...
