NEUTRIK NC4FX-BAG Silver Plated 4 Way Female XLR Connector Ø8mm (Unit)
Reference : 6437
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 25-04-2025.
These connectors are easy to assemble, with only four parts and no screws.
The contact block is made of hard plastic (polyamide) and is inserted through the back of the body.
The female contacts have a unique cage design with seven independent contact springs for low contact resistance and high integrity,
and incorporate a solder barrier to prevent the solder from flowing into the area of ​​the mating contacts.
The female connector has a larger, easier-to-handle improved solid metal latch, plus additional new spring-loaded contacts for better body mass continuity.
Features:/ Strong>
  • Fits on cables from 3.5 to 8.0 mm in diameter
  • Silver Plated
  • 4 poles
  • Welding
  • Black body
Insulation materialPE
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticFemale
Contacts number4
ConnectorXLR
Valeur sûre!
C'est du Neutrik et sans problème!!!!
This review has been posted for NEUTRIK NC4FX-BAG Silver Plated 4 Way Female XLR Connector Ø8mm (Unit)
