NEUTRIK NC4MXX Male 4 Poles XLR Connector Ø8mm
The Neutrik NC4MXX 4-pin male XLR connector will allow you to design robust audio cables. Its polyurethane ferrule offers high protection against mechanical bending of the cable and its zinc body ensures high durability.
Reference : 16905
4,70 €tax incl.
3,92 € tax excl.
Shipping date: 24-04-2025.
Neutrik NC4MXX
Neutrik NC4MXX Connecteur XLR 4 Pôles Mâle Ø8mm
The Neutrik NC4MXX 4-pin male XLR connector will allow you to design robust audio cables. Its polyurethane ferrule offers high protection against mechanical bending of the cable and its zinc body ensures high durability. The connector accepts cable diameters ranging from 3.5mm to 8mm.
Product typeMale 4 poles XLR connector
Min/Max cable diameterØ3.5mm / Ø8mm
Max cable section1.5mm² (16AWG)
Mounting typeTo solder
Capacitance between contacts≤ 7pF
Contact resistance≤ 3mΩ
Dielectric strength1.5kVdc
Insulation resistance> 10GΩ
Rate current per contact10A
Rated voltage< 50V
Insertion/withdrawal force≤ 20N
Lifetime> 1000 cycles
Boot materialPolyurethan
Contacts materialCopper alloy
Contacts platingNickel 2µm + Silver 2µm
Insert materialPolyamide
Shell materialZinc
Temperature range-30°C / +80°C
Certifications and standardsUL 94 V-0
IEC 61076-2-103
IP 40
IEC 68-2-20
Insulation materialNC
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticMale
Contacts number4
ConnectorXLR
The Neutrik NC4MXX 4-pin male XLR connector will allow you to design robust audio cables. Its polyurethane ferrule offers high protection against...
