RAMM AUDIO 60100-GT Gold Plated Tellurium / Berrylium Copper 3 Way Male XLR Connector Ø11mm (Unit)
2.0 / 5
Reference : 9455
54,90 €tax incl.
45,75 € tax excl.
This Ramm AUDIO XLR connector is made from carefully selected materials.
It is a very robust and high quality connector.
The conductor is made of Cryo-treated Copper Tellurium and Gold Plated Berrylium with Teflon insulation and a clean design with impeccable finish.
Features:
  • Conductor: Cryo-treated Copper Tellurium and Gold Plated Berrylium
  • Gold plated 3-pole male XLR connector
  • Brass body
  • Teflon insulation
  • Acceptable cable diameter: 11mm
  • Screw on
  • Dimensions: 57x19mm
  • Weight: 35g
  • Sold individually
Insulation materialPE
Max cable diameter (mm)11.0
Mounting typeTo screw
ConnecticMale
Contacts number3
ConnectorXLR
Contacts Material (Connector)Tellurium Copper
Contacts Material (Connector)Beryllium Copper
difficile à utiliser
Il faut un outil très spécial pour visser la petite vis.
Par ailleurs, la vis ne s'enfonce pas complètement; à n'utiliser qu'avec un fil d'au moins 1 mm.
This review has been posted for RAMM AUDIO 60100-GT Gold Plated Tellurium / Berrylium Copper 3 Way Male XLR Connector Ø11mm (Unit)
