REAN NEUTRIK RT3FC-B Female 3 Poles Mini XLR Connector Gold Plated Ø4mm
This Mini XLR 3-pole female connector accepts cable diameters ranging from 2mm to 4mm. Its contacts are gold plated to ensure good conductivity and durability. A clamping system allows to maintain the cable efficiently and limit the mechanical constraints on it.
Reference : 15672
2,30 €tax incl.
1,92 € tax excl.
Rean Neutrik RT3FC-B
Rean Neutrik RT3FC-B Connecteur Mini XLR 3 Pôles Femelle Plaqué Or Ø4mm
Product typeFemale 3 poles Mini XLR connector
Acceptable cable diameterFrom 2mm to 4mm
Max cable section0.22mm² (24AWG)
Contacts platingGold
Mounting typeTo solder
Contacts resistance≤ 10mΩ
Insulation resistance> 1GΩ
Dielectric strength> 0.5kVdc
Rated current per contact< 5A
Lifetime> 5000 cycles
MaterialsBushin : ABS
Contacts plating : Gold
Contacts : Copper alloy
Insert : PA 6.6 30% GF
Shell : Zinc
Insulation materialNC
Max cable diameter (mm)4.0
Mounting typeTo weld
ConnecticFemale
Contacts number3
ConnectorMini XLR
This Mini XLR 3-pole female connector accepts cable diameters ranging from 2mm to 4mm. Its contacts are gold plated to ensure good conductivity and...
