Gold Plated Male 3 Pins Mini XLR Socket (Unit)
This Mini XLR 3-pin male connector will allow you to take advantage of this particular connection technology on a DIY mounting. This is mainly used as a connector for certain headsets.
Reference : 13608
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 29-04-2025.
Mini XLR Socket
Connecteur Mini XLR 3 Pins Mâle Plaqué Or Ø5mm (Unité)
This Mini XLR 3-pin male connector will allow you to take advantage of this particular connection technology on a DIY mounting. This is mainly used as a connector for certain headsets such as, in particular, AKG. The contacts on this base are made of gold-plated copper to ensure very good conductivity of the audio signal.
Product typeMale Mini XLR Socket
Number of pins3
Contacts materialCopper
Contacts platingGold
Max panel thickness6.5mm
Connection typeTo solder
Total dimensions17.3 x ⌀15mm
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
Contacts number3
Max panel thickness (mm)6.5
ConnectorXLR
This Mini XLR 3-pin male connector will allow you to take advantage of this particular connection technology on a DIY mounting. This is mainly used...
