NEUTRIK NC3FP-B-1 Female XLR 3-Pin Female Socket
New
This low-cost Neutrik NC3FP-B-1 3-pin female XLR socket is ideal for mounting on your DIY cases. Its gold-plated contacts ensure good conductivity and durability against corrosion and oxidation.
Reference : 20708
6,90 €tax incl.
5,75 € tax excl.
NEUTRIK NC3FP-B-1 XLR 3-Pin Female Socket Gold Plated
NEUTRIK NC3FP-B-1 : Front view
NEUTRIK NC3FP-B-1 : Dimension
Product typeXLR socket
Connector genderFemale
Contact materialCopper alloy
Contact platingGold
Body materialZinc diecast
Locking element materialSteel
Locking element platingNickel
Temperature range-30°C ~ +80°C
CertificationsUL94HB
IEC 61076-2-103
IP40
Electrical characteristics
Capacitance between contacts≤ 4 pF
Contact resistance≤ 5 mΩ
Dielectric strength1,5 kVdc
Insulation resistance> 10 GΩ (initiale)
Rated current per contact16 A
Rated voltage< 50 V
Mechanical characteristics
Insertion force≤ 20 N
Withdrawal force≤ 20 N
MountingSoldering contacts
Dimensions36.7 x 27 x 21mm
PackageSold by unit
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticFemale
Contacts number3
Max panel thickness (mm)N/A
ConnectorXLR
This low-cost Neutrik NC3FP-B-1 3-pin female XLR socket is ideal for mounting on your DIY cases. Its gold-plated contacts ensure good conductivity...
