VIBORG CF201 (R) 3 Poles Female XLR Panel Plug Silver / Rhodium Plated Pure Copper (Unit)
This 3-pole XLR female Viborg CM201(R) XLR base has an exemplary design thanks to the use of the best materials. Indeed, the contacts of the base plate are made of 99.998% pure Copper to ensure an excellent conductivity of the audio signal. The contacts are also silver and rhodium plated.
Reference : 13362
23,90 €tax incl.
19,92 € tax excl.
Viborg CF201(R)
Viborg CF201(R) Embase XLR Femelle Cuivre Pur Plaqué Argent / Rhodium (Unité)
This 3-pole XLR female Viborg CM201(R) XLR base has an exemplary design thanks to the use of the best materials. Indeed, the contacts of the base plate are made of 99.998% pure Copper to ensure an excellent conductivity of the audio signal. Contacts that also benefit from a double silver and rhodium plating. Silver being the best conductor, it allows to maximize the transmission performance of the base plate, where Rhodium will protect the contacts from corrosion and thus considerably extend its life span.
Product typeFemale XLR panel plug
Number of pins3 pins
Contacts materialPure Copper
Contacts platingSilver / Rhodium
Body materialCNC machined Aluminium alloy
InsulationPTFE
Total dimensions26 x 31mm
Cutout diameter21.2mm
ColorGray
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
Contacts number3
Max panel thickness (mm)N/A
ConnectorXLR
Très belle embase.
J'ai mis cette embase sur un ampli DIY à base de modules classe D de Purify.
Elles sont lourdes, massives, très bien usinées et à la finition parfaite.
Le maintien du connecteur de la même marque XF-202R est très bon avec une petite bille.
L'isolant téflon assure une excellente isolation et un confort supplémentaire lors du soudage.
Oui car pour souder sur le rhodium, il faut soit gratter un peu ce rhodium soit chauffer assez fort avec du flux.
Mais ça se fait sans problème.
This review has been posted for VIBORG CF201 (R) 3 Poles Female XLR Panel Plug Silver / Rhodium Plated Pure Copper (Unit)
This 3-pole XLR female Viborg CM201(R) XLR base has an exemplary design thanks to the use of the best materials. Indeed, the contacts of the base...
