YARBO GY-30XSC Male XLR Plug Caps (Pair)
Reference : 5208
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 22-04-2025.
This accessory protects your unused XLR plugs from oxidation and dust that can get inside your amps or any other audio device. Look at your unused XLR plugs after a few years of exposure to air and dust: oxidation, dust accumulation, deterioration of the plating. Things that can rarely be recovered. Thanks to these useful little plugs, you can improve the life and appearance of your equipment.
The cap made of an alloy of Brass and Nickel is an effective barrier against electromagnetic micro-pollution. The insulation of the XLR terminal thus protected is total, the dust does not penetrate in the device, its lifespan is prolonged.
Max cable diameter (mm)N/A
Mounting typeN/A
ConnecticN/A
Contacts numberN/A
Max panel thickness (mm)N/A
ConnectorN/A
Contacts Plating (Connector)N/A
Capuchons pour connecteurs felelles XLR
Excellent produit très bonne finition avec un plot de détrompage relié à la masse du capuchon donnant une barrière plus efficace pour les EMI / RFI
This review has been posted for YARBO GY-30XSC Male XLR Plug Caps (Pair)
