Marc A.
Parfait
Mon lecteur réseau Teac NT 505 X possède une sortie casque 3,5mm à 4 pôles. Hors tous les jacks proposés en 3,5mm sont en 3...
Fabian b.
superbe tube .fonctionnent très bien sur un Cayin cs150
.j aimerais savoir si ils sont disponible en quad appairés. Merci pour vos réponses..
alexandre G.
excellent
couplé a un streamer eversolo sur les liaisons symetriques... tout y est!
puissance , details , profondeur et le tout dans une...
ALLO Boîtier Acrylique pour Allo DigiOne et Raspberry Pi 3 Noir - avis - Il y a 6 avis.
Bruno C.
ALLO boitier pour DigiOne et Pi 3
Le rapport qualité / prix est très bien.
Je suis pas très bon bricoleur, mais sur Internet on peut trouver des video de montage ... bref, montage facile et clair.
Seul petit regret : non transparent : suivi visuel des leds impossible.
D. v.
Looks nice, does its job well
The case looks good, although it is not transparent as in the images (solid black).
A little work to get the protective paper layer off, but some hot water and it peels off pretty easily.
Assembly is a breeze, but make sure to place remove the screw ring on the DigiOne coax connector before adding the sidepanel, or it wont fit correctly.
Martijn v.
Not as described
The only reason I bought an Allo Digione board for Rpi at Audiophonics and not some other supplier was because Audiophonics also sells this case. I think the see through acryl looks awesome. So I was pretty dissapointed when I opened the package and the case was not seethrough acryl with a dark shine, but just plain old black. BLACK, totally black, no see through whatsoever. If I had known this I would have looked elsewhere. So only 2 stars just because it's a case, but i'm pretty dissapointed with Audiophonics for selling a product that realy differs from the picture advertised above...
Damianos D.
Practical case, almost as described
The characteristics and dimensions of the case is as described. It has anything you might need for assembling a pi2/3 with a digione, even screws and spacers provided also by digione. The assembly is easy and intuitive. However, in my case it was not a black acrylic but a light brown cardboard. I'm OK with that, I would order it in any case, but for this difference in description I can't give the fifth star.
Pieter T.
Good case, hard to assemble
Good case, sturdy and looks great. Only thing, it is a pain to assemble, took me 1 hour, not very intuitive. But once assembled, everything perfect.
Patrice G.
Très belle qualité
Ce boitier est très qualitatif pour de l'acrylique.
Il est parfaitement conçu, l'assemblage est facile, le Raspberry Pi est fixé par quatre vis et l'ensemble ne dépare pas parmi les autres éléments de la chaîne.
Je recommande.
